Hi all,
In the process of trying to debug some playback issues with Plex app on my Apple TV 4K it was recommended to try Infuse 6 and I’m trying to understand the advantages/disadvantages to this approach.
Overall I’ve been pretty happy with the performance of Plex running on a Windows i7 based server back-end and feeding out Plex to the Plex app on my various devices, most of them now are 1080P Apple TVs.
I recently upgraded my main viewing area and purchased a 77" LG OLED TV and an Apple TV 4K. I noticed after this upgrade a couple of issues with the Plex app;
I am getting “bit rate choking” when playing higher bit-rate MKV files from my library. None of my content is 4K so at most these would be 1080P BD rips where I ripped the full bit-rate Blu-ray using MakeMKV to an MKV file, these files might include VC-1 video codec, True-HD audio codec, etc. Normally my expectation is that these files get transcoded by the Plex server since the Apple TV can’t handle these codecs. When the bit rate is too high or the codec seems to be incompatible I will notice bad video stuttering, macro blocking, etc., and this is usually cured by one or more corrective actions such as limiting playback to 20mbps 1080P or disabling direct play in the Plex app.
I am getting “micro stutters” during playback. These are tiny jumps in the picture, some users might not notice them, but I do. I don’t observe these micro-stutters in other apps just the Plex app.
How will Infuse help me out here, or will it? I tried setting up the Infuse App, pointed it to my existing Plex server and it immediately wanted me to do a subscription. Before subscribing I want to better understand what I would be getting out of Infuse that Plex is not doing for me.
P.S. I have an Intel NUC system that I use Kodi on that I used to bust out when I wanted to watch my full bit rate HD stuff as it can convert HD audio formats to PCM, etc. It’s not clear to me if Infuse would also allow me to relegate this machine to the dust bin of history.
