Will installing the Flash plugin reduce the amount of times Couch Surfer crashes? I mean that thing constantly crashes, especially on sites that use flash… Any ideas?
I can’t say for sure, but I know that Couch Surfer has had a big history of crashing for me. At least aTV Flash 3.3.5 has made it fairly easy to install Flash. You just have to be able to transfer the CoreAudioKit from a 10.4.x Intel computer to the AppleTV’s frontrow Documents folder.
You will need to have Flash enabled to use sites that feature Flash content. This unfortunately is a bug in Couch Surfer.
