any update for subscene ?? or any sloution to add subs From cloud for example to Apple TV App
I saw https://subscene.com/ has more subtitles per title than opensubtitle. So please consider this and hope to see it in next update.
I moved your post to a currently running thread requesting this feature.
Don’t forget that you need to click the like button on the first post in this thread to show your support for this suggestion!
How is the timing with 中文 subtitles when using them from subhd.tv? I find that I have to adjust the timing of them in about 50 percent of the time if they are off when using opensubtitles.
No updates to add subscene (subs source) to infuse?
Any news about subscene support?
Or load sub from cloud services?
Hopefully in 8v
Hi all …
any updates?
I see in reddit some subjects & plugs … to bring subscene search in emby !
Maybe same idea for infuse
Please see that james
Hi guys… First off all superb piece of software.
I was wonder if it’s possible to add subtitles from titlovi.com
The subtitles are in English, Croatian, Serbian, Bosnian, Slovenian (exYU region). It has all up to date subtitles for all new series and movies!
There is already a official Kodi addon and it seems they use some sort of API
Is it possible to add this subtitle source to Infuse!
Binnen infuse is het ingebakken om gebruik te maken van opensubtitles. Vaak zijn subtitles daar niet aanwezig. Het zou fijn zijn als er een mogelijkheid was om zelf andere subtitle aanbieders te kunnen toevoegen.
Google Translation
Within infuse it is baked in to make use of opensubtitles. Often subtitles are not present there. It would be nice if there was a possibility to add other subtitle providers yourself.
If you provide an English translation to your posts you will get more responses and it helps us help you.
Also don’t forget that you need to click the like button on the first post in this thread to show your support for this suggestion!
Welkom op het forum!
Als je een Engelse vertaling van je berichten geeft, krijg je meer reacties en helpt het ons je te helpen.Vergeet ook niet dat je op de vind-ik-leuk-knop op het eerste bericht in deze thread moet klikken om je steun voor deze suggestie te tonen!
