Adding Cover Art to Movie Difficulties & Errors when trying to add art for favourites or folder art
  1. I’m having a heck of a time trying to add “movie_space_whatever.jpg” to “movie_space_whatever.m4v”. I have use local metadata enabled but it’s just not showing up with my cover art. Any ideas what’s going on here? I am using SMB sharing.
  2. When I try to add folder art using the naming convention “favourite-atv.jpg” I get an error message when I try to add art work via the “hold down button options”. Something like “This operation cannot be completed”. Any suggestions for this one?
Thanks :slight_smile:
Paul
If Infuse has already cached metadata for these files, then you would need to use the ‘Edit’ option to reload metadata in order for the new artwork to be picked up.
With regard to the favorite artwork. One thing to check is the name, as Infuse will look for ‘favorite-atv.jpg’ but not ‘favourite-atv.jpg’. We’re trying to keep it simple by sticking with the US English phrasing for now. :wink:
