Add progress indicators for partially watched episodes
I don’t get the UX. The current unplayed episode is what you get in the show’s play button, that’s clear.
But on the bottom, on a per episode image, shouldn’t there be a progress marker on each of the played episodes? What if you’ve stopped in the middle of one and want to see where you stand?
When opening a season, Infuse will automatically select the first unfinished episode, and the progress for this episode will appear in the in the Play (Resume) button.
That’s clear. What I’m suggesting is that the progress per episode should still be visible on the episode icons below.
Ok, I’ve renamed this and moved to suggestions.
