I uploaded a sample Profile 5 Dolby Vision MKV file (from Index of /download/dvtest) that Infuse 6.5.2 on Apple TV 4K plays in SDR.
Video
Format : HEVC
Format profile : Main 10@L5.1@Main
HDR format : Dolby Vision, Version 1.0, dvhe.05.09, BL+RPU
Codec ID : V_MPEGH/ISO/HEVC
Duration : 56 s 200 ms
Bit rate : 27.7 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 60.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.056
Stream size : 186 MiB (98%)
Language : English
Default : No
Forced : No
The latest Plex on tvOS will trigger Dolby Vision on newer files made with MakeMKV. Is this just fake “DV” that triggers that mode on the TV, or are they doing some trickery to actually get the Apple TV 4K to play these? This is using the latest Plex for tvOS beta. I didn’t test much, but the image did look like “real” DV to me. It would be great if Infuse could add support for these - but maybe it’s not real DV.
The current 7.3.10 version supports as much Dolby Vision as (currently) possible. A list of the supported types (with fallback order) can be found here in this post.
