Add Direct URLs in bulk
It would be nice if I could point Infuse to a text file that has all the direct URLs I want in the library. Even if it was just a single time upload bulk add it would be nice, but even better if it would sync with the file.
Even if I could just add a text file via what used to be called “iTunes File Sharing” (in the Finder now, not sure what they call it). I’m just wanting to move all my stuff to Direct URLs, and putting them in one at a time is not a great way to handle it.
Another way to handle it would be to support .webloc files (or some other form of URL as file). You could create a simple share with a file for each URL.
Noticing this suggestion:
Adding support for .strm files would be one solution to this.
+1 Would love to see this feature
Instead of adding an episode individually.
This is not supported at the present time, but I’ve moved your post to a currently running suggestion thread. :slight_smile:
Hi, adding Direct URL links works fine all the while for single url. How do we add multiple url links easily without adding 1 by 1. Can we use .m3u playlist for this purpose. I’ve tried but only the first url could import. Anyone has tried this? Thank you.
I hope to add features to your app for adding files by Adding more than one url link in one time by paste it in new URL table, Adding one by one wasting time and a need lot of effort
In a CSV format or just recognizing multiple URLs on Mac. It’s a pain to add multiple links (>10) one-by-one
I moved your post to a currently running thread for that suggestion.
Hi i have many moves witch i need use direct links to add infuse is there any option i can copy all links and pase to some file and that file infuse can read like it has many links or use one link to open many links
I moved your post to a currently running thread in the suggestions forum requesting this feature.
We hope you will post one link, for example
We need this to paste the series link
We don’t want to paste just one single link
Example past all url
Today’s 7.6.2 update adds the ability to add links in bulk through the use of a simple .links text file.
Adding a .links file to Infuse (via Files, AirDrop, etc…) will allow you to import many links at once instead of having to add them individually one at a time.
Download a sample .links file
Note: .links files are plain text documents with the extension changed from .txt to .links. Be sure to use a plain text editor to create and edit .links files. Apps which add extra formatting such as Microsoft Word will not work.
