Add confirmation for deselection in “Library”
I realized there’s a problem in the library section.
The problem is that on the iPhone, when I have many folders, I have to move to see if they are on favorites or not.
Well, as you slide your finger if you play if you want the Tick of selection disappears and if you put it back as it was, then go back and search the whole conten in my case is hours and days.
I think if you mistakenly pull us out a message “you are sure to deactivate the folder”
Or something like that because my folders have more than 10K of movies and 30K of chapters.
I show in this capture the tick I’m talking about.
It takes off with just grazing it.
