How can i turn up/down the audio sound inside infuse app. I cannot find that.
Being similar to iOS it is probably just using the system volume. Not a separate control like with VLC.
One suggestion I would make is to separate the app volume control from the system volume.
And as always, thank you for your effort. I had some issues with the first release, but this is very usable now. This was a great Christmas gift
