Accidental 4.4.4 Upgrade
Just upgraded to 4.4.4 like an idiot.
Is there any way I can downgrade to a previous version that can be jailbroken?
Please help!
Thx!
Just repeat the jailbreak process.
Do I jailbreak with the old 4.3 version or use the new 4.4.4 tethered?
Thanks Again!
well I rejailbroke it with 4.4.3 because of a possible untethered fix soon.
Hope that is what I shouldve done.
It depends on whether you are happy with a tethered jailbreak? You will have to re-do the jailbreak anyway if you start with a tethered jailbreak and later want to switch to an untethered jailbreak.
Just make sure you backup your SHSH blobs with Tiny Umbrella. That way you can always go back.
