Accessing network storage on nitoTV
I’ve got a network storage device (Terastation) that I can view fine via any laptop on my network - via \terastation\share. I can access this fine through XBMC as well - it has a network browsing capability so it’s just a matter of finding and selecting it through the file browser. I can’t seem to get access to it through nitoTV. Nito requires me to “Add Manual Share Point” and then asks me for a Mount Name, Network Address, and a Path. I’ve tried every permutation of “terastation” and “share” and can’t get it to work - I keep getting: “mount_afp missing, cannot mount”
Any advice?
I am running into exactly the same error - except using Synology NAS versus Terastation. Is this an indication of a user error or inability to use a NAS. The NAS supports an itunes server but from other posts it sounds like you can’t setup ATV with a NAS based itunes server so was hoping I could at lease use SMB approach for accessing the NAS content from the ATV.
Any advice would be much appreciated.
Thanks,
Doug
It was a user error in my case :-o
I had the wrong mount type specified. It was set to afp. I was pretty sure I didn’t select that in the first place but must have somehow. My NAS appears mounting fine now.
–Doug
What did you do to change from afp?
It took me 2 YEARS to figure this out. This information is very hard to find… I found it on the nito site (seems that they heard people had so much trouble doing this…)
I connected to a WHS and a generic NAS successfully for the first time this weekend by doing the following:
Mount name = anything you want it to be
Network Addy = the computer or device’s name as it is known on the network. do NOT use any special characters
vol path = the folder you want to connect to. again, do NOT use any special characters. a top-level folder will give you drill-down access to sub-folders
use “SMB” as the connect method first, if that does not work you can try others.
For a WHS, i can’t remember but I think you must engage authorization, and use “guest” (with no password) to access the WHS shares
For a NAS, same thing… set up a username (with or without password) to allow the ATV to access.
Having said all that, and after mounting via NITO, I can watch just one movie then it kills the ATV. Blank screen. I hear it going through menus but I see nothing. Sapphire is worthless… totally reboots the ATV and does nothing.
I can, however, use XBMC and Boxee to read everything in the networked folders. Plays with a funky screen ratio, but I can overscan on the LCD to fill it all in. Sound is perfect, in surround sound.
Extremely happy I don’t have to convert all my VOB’s into apple quicktime movies and stream them anymore! 9 TB is enough :frowning:
