I have successfully gotten network access working as well as usb support. My only question now is how can I access the drive from my computer? The drive shows up in the ATV menu and I can access the files over cyberduck. When I try to access the same drive through finder, I can see the volume. Inside the volume are only two folders, but they are empty.
I type this into the “Connect to Server” window:
afp://appletv.local/frontrow
All other settings are directly from the knowledge base forum.
I can transfer files that are on the ATV drive without issue, so is there a way of doing this with the external hard drive?
