AC3 passthrough in v3.4.3
Does AC3 passthrough work again with ATV Flash v3.4.3? I tried v3.4.1 and v3.4.2 and it did not work.
Thanks.
well my ac3 passthrough worked fine in the last version… so i would say mine works in this version what are you looking for dolby digital? DTS? or pro logic? most surrond sound systems won’t reconize the apple tv as putting out dolby digital… unless you burn it to a disk. Other why you would be use pro logic if your dvd system is equipped.
