For 2 days now I tried to edit metadata for a French tv show I’m currently watching but without any luck.
Astrid et Raphaëlle (2020)
It was there before and my first few episodes have the correct information, but not now, I don’t know if the API is broken for (thetvdb) or (themoviedb) or not
Currently, Infuse doesn’t recognize videos that have been split from their original length. You’d need to join the parts back into one episode and then you’d have to rename the files.
For example, the one you have provided the file names for would be
“astrid et raphaelle S00E01 Puzzle.mp4” and the sub would be
“astrid et raphaelle S00E01 Puzzle.srt”
Note for specials the format used by infuse and TVDB is S00 for specials and then the E01 for the first special.
The same would apple to all episodes. They would have to be joined and renamed as above with season 1 and so on.
