A specific DV doesn't work or fallback to HDR
LG: Dolby Vision UHD 4K Demo | 4K Media
It is .ts file you can download from above link. it just plays as 4K and has some lag until it displays the video as well.
LG DV.txt (2.3 KB)
Here is metadata ^
That’s a Dolby vision profile 4 file. I don’t believe those are supported by AppleTV hardware. There’s also only one video track so there isn’t any HDR to fall back on.
Thank you for the explanation, this profile wasn’t mentioned in fall back thing so I was wondering about it.
so basically no apple product can play this file. I tried this on mac tho.
No apple product can. You might be able to on a windows PC using specialized software.
