Just bought a Apple Tv and a copy of ATVFLASH!
All working great, but I have a few minor problems/questions though…
1 - I tried uploading a 1.3gb file via (Smart) ftp…It takes an age (maybe an hour). But also i notice it times out alot and restarts from scratch, so i never actulaly got the file to my Apple Tv. Im not sure if its a problem with ATV or my network, but does anyone have any ideas?
2 - Because the above failed I simply copied the files to a USB stick, pluged it in and watched it via the USB Stick (which worked really well btw). But is there a way of copying files off the USB directly to the APPLETV?
3 - Is there a way to use a two way patch cable to upload files quicker - IE one network cable from laptop to appletv?
4 - or…can i connect the ATV to a laptop via a usb lead?
Think thats about it, any help and advice would be great!
