A couple of questions
When playing a movie Can You change subtitles, and language ?
Does it play iso Or img files ?
Can You type in the information about the movie yourself ?
Hope You have time to answer my questions. I Really dont know If i wanna use xbmc Or firecore.
Firecore seems to be easy and fit in with the Apple gui, But i cant find anything about the subtiltle question, which is extremely important :wink:
Xbmc looks great, But have alot of extra things i Really dont need. :slight_smile:
And does it support Fanart ? Fanart and shown covers, looks great i Think.
And does it work with the menu on the film ?
Really the only important things should be working with menu, and able to change subs .
