Anyone else having problem with top shelf on the Home Screen since update - not showing anything now or is it just me?
Can you check to ensure ‘Up Next List’ is enabled in Settings?
I had that problem on one of my ATVs after the previous update and a reboot of the ATV solved it.
Thanks, appears to have fixed itself overnight. Should really have some patience…
