7.3.5 Opus audio codec issue
My Apple TV downloaded of Infuse 7.3.5 overnight and all my videos with Opus audio codec no longer work (regardless of video codec and resolution). Screen goes black, white spinning thing appears in the centre and it returns to episode selection screen few seconds later. Videos with AAC audio stream do not have a problem
For example:
$ mediainfo /srv/media/youtube/YouTube/Season.01/Youtube\ S01E6558\ gameranx\ -\ Elden\ Ring\ -\ Before\ You\ Buy.mkv
General
Unique ID                                : 317344494909381971523701794523395070393 (0xEEBE53985681C07C80006124DF7319B9)
Complete name                            : /srv/media/youtube/YouTube/Season.01/Youtube S01E6558 gameranx - Elden Ring - Before You Buy.mkv
Format                                   : Matroska
Format version                           : Version 4
File size                                : 951 MiB
Duration                                 : 12 min 57 s
Overall bit rate                         : 10.3 Mb/s
Movie name                               : Elden Ring - Before You Buy
Writing application                      : Lavf58.20.100
Writing library                          : Lavf58.20.100
Cover                                    : Yes
ErrorDetectionType                       : Per level 1
Attachments                              : cover.png
Video
Format                                   : VP9
Codec ID                                 : V_VP9
Width                                    : 2 560 pixels
Height                                   : 1 440 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 60.000 FPS
Color space                              : YUV
Language                                 : English
Default                                  : Yes
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
Audio
Format                                   : Opus
Codec ID                                 : A_OPUS
Channel(s)                               : 2 channels
Channel layout                           : L R
Sampling rate                            : 48.0 kHz
Bit depth                                : 32 bits
Compression mode                         : Lossy
Language                                 : English
Default                                  : Yes
Forced                                   : No
Just tested my Opus 2ch videos on iPhone Infuse 7.3.5 and they seem to work fine
Interesting. Installed Infuse on my phone and I still have the same problem. The only difference is that spinning while thingy seem to be present on iPhone for much longer than on Apple TV.
Interestingly enough, I am able to resume playback of videos (e.g. if I am half way though), but I cannot start them from the begining (if I mark them as unwatched and start playing).
I am using Jellyfin with Infuse plugin and Infuse on Apple TV.
Does downloading these from Jellyfin to Infuse (on iOS) and playing them locally make any difference?
Can you upload a sample file we could review here?
Hi James,
File did not play locally on my iPhone after downloading it from Jellyfin. I have uploaded the file to your dropbox.
mediainfo Youtube\ S01E6545\ Linus\ Tech\ Tips\ -\ I\ better\ not\ screw\ this\ up\ -\ Intel\ \$5\,000\ Extreme\ Tech\ Upgrade.mkv
General
Unique ID                                : 4263317945847775478155277895894439225 (0x33515CDAA02ADB80DC8E3874C5A1539)
Complete name                            : Youtube S01E6545 Linus Tech Tips - I better not screw this up - Intel $5,000 Extreme Tech Upgrade.mkv
Format                                   : Matroska
File size                                : 1.91 GiB
Duration                                 : 23 min 58 s
Overall bit rate                         : 11.4 Mb/s
Movie name                               : I better not screw this up - Intel $5,000 Extreme Tech Upgrade
Cover                                    : Yes
Video
Format                                   : VP9
Codec ID                                 : V_VP9
Width                                    : 3 840 pixels
Height                                   : 1 920 pixels
Display aspect ratio                     : 2.000
Frame rate                               : 29.970 (30000/1001) FPS
Color space                              : YUV
Language                                 : English
Default                                  : Yes
Forced                                   : No
Audio
Format                                   : Opus
Codec ID                                 : A_OPUS
Bit depth                                : 32 bits
Language                                 : English
Default                                  : Yes
Forced                                   : No
We have a fix for this coming in 7.3.6.
If you’d like to test a beta early, drop me a PM and I can add you to TestFlight.
Thanks for such a quick fix. I will just wait for the next release and use AAC tracks for now.
Interested in testing this.
Invite sent. :slight_smile:
Thank you for the invite
This has been resolved in today’s 7.3.6 update.
Thanks for your patience.
