7.1 and Plex
Hi all,
I connect Infuse to a plex server to allow for multiple libraries and custom collections.
Plex has the option of TVDB and TMDB for metadata.
Will Infuse 7.1 keep the Plex metadata or overwrite it to TMDB after this update is installed?
Your Plex meta isn’t affected by upgrade
Thanks for the response!!
Correct. When using media servers like Plex, Emby, and Jellyfin Infuse will utilize the metadata stored on these servers instead of fetching its own.
