576p (PAL) content being tagged as 720p
OK,
Given the fix for this in the 6.0.4 release, I wiped all my metadata and did a complete scan of the library to make sure all my 576p material was correctly tagged. First material I checked still shows a TV Show as 720p, even though the library resolution filter tags the material as SD. MediaInfo extract below. I will check all my DVD rips for the same later today. Am I missing something here?
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 57mn 0s
Bit rate : 1 203 Kbps
Width : 1 024 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.082
Stream size : 491 MiB (90%)
Writing library : x264 core 148 r2643 5c65704
Is Infuse possibly restoring incorrect metadata information from iCloud? How do I delete all the iCloud metadata so as to get a clean slate?
I don’t know if it’s storing it in icloud but if you have a Mac you can go to System Preferences > iCloud > Manage > Click on Infuse Pro 6 then click on Delete Documents and Data
If you’re using an ios device it’s Settings > tap on your profile > tap iCloud > tap Manage Storage > Under Documents & Data tap Infuse Pro 6 > Tap Edit > Tap Delete All
Can you try using the Edit option on one of the affected files, re-selecting the correct title, and see if the correct specs pop up?
Unfortunately, editing the metadata does not cause the resolution to change from 720p.
Confirming that ALL movie content is correctly tagged at 576p for my PAL DVD rips, its just this damn TV show that wont change. Even though Infuse puts it in the SD category on the resolution filter.
