5+ Seconds to Resume Play + Stuttering Issues
2023 Mac mini M2 Pro on Ventura 13.2.1, Infuse Version 7.4.10 (7.4.4329) - says v7.5 is out but isn’t showing up in App Store yet fyi…
There’s a good 5-10ish second delay before a video will play again after pausing a movie (not all movies, just some). This does NOT happen on the same exact file, on the same network drive, with other players like VLC, Optimus, etc… I get 200mb/sec up/down off that drive and these are only ~2gb files (i.e. bandwidth isn’t an issue).
Screen recording of the delay upon un-pausing.
2nd (maybe related?) issue is the video stuttering. Usually happens after rewinding or fast forwarding (with left/right arrow), and usually only for a few seconds. Sometimes won’t stop until I pause, then un-pause.
Again, this does NOT happen on the same exact file, on the same network drive, with other players like VLC, Optimus, etc…
Screen recording showing the stuttering.
This happened on a completely different 2023 mac Mini as well, so it isn’t the computer or the install either fyi.
Just to update, Infuse updated to Version 7.5 (7.5.4381) the other day… problem STILL persists (taking 5-10 seconds on certain movies to resume playing after pausing).
Again, this does NOT happen on the same files, on the same network drive, on any other video player I use.
Anything I can try? I pause a LOT… and it’s making using Infuse (which I pay for every month) almost unusable… (or at the very least extremely annoying…).
What do you have the Streaming Cache set for in Infuse preferences?
Can you replicate this issue and send in a diagnostic report from your device (and post the 5 digit code here)? This will assist us in troubleshooting this further.
I have this issue for months now, too! But only on AppleTV 4K (latest). Got this issue with every single file but didn’t worry me too hard to not accept so far
Report sent: 84EWN
