5.4.5 problem
There appears to be a bug in Infuse 5.4.5 where if a share contains more than about 775 video files the share reports as empty. When I moved 40 of the files to a different share the original share reported correctly. Anyone else have this issue?
Same problem here. Only some files give me loading error. Not all files in a folder. Problem just started a few days ago and it doesn’t work on iOS or atv cause I checked both. Same files not showing on both iOS and ATV.
Can you send in a report from your device so we can look into this?
