So i just updated my appletv 2 to 5.3 without any issues. But i am now trying to save the Blobs as i never even knew i had to do this. Ive been jailbreaking ios devices since they first JB an apple product and never paid attention to this SHSH saving as i was lucky enough to never encounter problems
Â
Anyways what i have tried so far.
Used Tinyumbrella (Mac) uncheked save all possible SHSH and also Cydia option, as i was told to do so on other forums and youtube… but nothing happens.Â
Forgot to mention also tried using latest version of Seasonpass by right clicking create IPSW and nothing happened as well
Here’s a case where it’s really best to get iFaith 1.5.9 on a Windows machine (ask a friend if you don’t have one handy) and save it that way.  You don’t even need to bring your ATV2, just simply have your ECID handy.
That way you ensure you have it. Â Â
I believe TinyUmbrella is no longer being supported.
When i connect the appletv 2 via micro USB windows attempts to install the drivers but is unable to because it says my devices is in recovery mode… I thnk i had this same issue before.Â
oh thats ok, id prefer to keep them locally, im not very familiar with the whole cydia/ifaith server and stuff.Â
The only thing like i mentioned when i click the right option in ifaith, i get an error saying something about hooking itunes? also is there a reason my appletv is in recovery mode after being JB and having XBMC installed? When connected to the Tv its perfectly fine, but connected to a windows pc its in that mode…
Yup you’re fine. The PC puts it into DFU mode either because of iTunes or iFaith. But as it’s untethered and you can connected it to the TV fine, there’s nothing to worry about.
You should be all set if iFaith said it was successful.
Thank you Chevy45, Ped and Hotbird for all your help and responses!
So i managed to finally save my Appletv 5.3 Blobs, and this may be a dumb question, but my sister also has a AppleTv i recently updated to 5.3. I was wondering if me saying my blobs was good enough and didn’t need to save hers? Or does (im pretty sure i know the answer) each AppleTv need its seperate blobs saved…
