5.0.1 and 5.0.2 giving error 3194 when not on stock iOS...
Please no n00b responses I just want to see if anyone had run into this prior because I did resolve it and will post solution but it is definitely weird.
Apple TV 2 running iOS 5.0.1 jailbroken with Seas0nPass w/ aTV Flash (black) installed (not that it makes a difference). When trying to flash a jailbroken IPSW of either 5.0.1 or 5.0.2 3194 would pop up. There were no redirects in the HOSTS file that would redirect the request for SHSH blobs to the Cydia server.
Used both Seas0nPass and iREB method for PwnDFU mode and still both would throw 3194.
I flashed to stock iOS 5.0.2 and it took fine no 3194. I then used iREB and put the Apple TV into PwnDFU again and was able to restore the jailbroken IPSW for 5.0.2.
Question now is has anyone run into this and what could possibly cause it?
