4K not working probably on mesh
Hello,
I have infuse running on apple tv hd(updated to last tvos) connected via wifi (deco x20 mesh, 5 ghz) to 200 mgb fiber connection, but i can’t run 4k content! The picture always freeze! Is there any solution to that? Regards
You’ll need the AppleTV 4K to play back 4K content. The HD doesn’t have enough horsepower.
Also you will probably want to connect to gigabit Ethernet for doing 4K.
The ATV HD is only 100Base T Ethernet.
Thank you.
Regards,
Abdullah S. Altamimi
Yes I know. I was adding to previous comment about needing a 4K version.
