4K HEVC file not playing, not showing correct resolution on info screen
When I try to play this file, I get:
“An error occurred loading this content”
I am unable to refresh either, without getting a similar message. Also, on the info screen, the resolution is showing as 1080p.
Now, when I play the same file in Plex, it plays fine and the correct resolution is displayed. I’m on the latest versions of both Infuse and tvOS.
Happy to send you a sample.
Format : HEVC
Commercial name : HDR10
Format profile : Main 10@L5.1@High
Codec ID : V_MPEGH/ISO/HEVC
Duration : 2h 8mn
Bit rate : 50.9 Mbps
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) fps
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.256
Stream size : 45.7 GiB (89%)
Writing library : ATEME Titan File 3.8.14 (4.8.14.0)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 929 cd/m2
Maximum Frame-Average Light Level : 129 cd/m2
Do you have multiple versions of this title by chance?
If so, the upcoming 5.7.4 update will add support for selecting which version (4K, 1080p, etc…) to play which may resolve what’s going on here.
