4K content
Simple question. Does Infuse would gave me the possibility to play 4k/hdr content from Plex without transcoding on the ATV 4k ? Even with SRT subtitles ?
I’m looking for a box and app that will always direct play and never transcode 4k content
thanks
Yes, Infuse will be able to direct play your 4K videos with SRT subtitles.
No transcoding required. :slight_smile:
Thanks !
Now I’m testing the free version of Infuse. Question. I do a some « optimized version » of some movies and tv shows for other platforms in Plex.
I’m now trying the find in Infuse if there is a way to chose which version I want to play
The ability to select a ‘Play Version’ will be available soon in the upcoming 5.7.5 update. :wink:
Nice! Now I can start shopping 4k tv :slight_smile:
If you live in the United States, I got my apple tv 4k for $105 through Direct TV Now streaming. You prepay for 3 months of service($35 per month = $105) and they send you a free apple tv 4k about a week after you sign up. You can cancel the service a few weeks before the 3rd month is over, but you should try it out, it works very well and is cheaper than cable. https://www.directvnow.com/appletv
but I live in Canada so I have free healthcare but absolutely no other promotion or lower prices on anything else :biggrin:
If you’re single, you can find yourself an american spouse. Then buy stuff using a vpn and have it shipped to their relatives house in the U.S. and then make some occasional “visits” to pick up your things :wink: Then you can have your cake and eat it too.
hahaha good idea ! Definitely not time consuming and overpriced !
