I’m having the same problem. If you have the ATV2 check for updates it says it’s up to date despite being on 4.4. If you try to do a complete restore it errors saying it can’t download and try again later.
There used to be a fire core setting in Maintenance >> Setting to block/allow ATV updates but that setting is no longer their.
Basically we are stuck with no way to update or retore.
step3. THE STEP U NEED: go down the list there will be 2 firmware 5.0(9B199s and 9B206F). you need to select 9B206F if you don’t have the option of 2 then ur down loaded of the new season pass was down loaded correctly, but you havn’t gone in the correct folder and open it to run, so lets just simplify it for you just sign in your computer as a guest. then down loaded season pass as a guest now it will be the most recent verison.
If you update to the newest version of season pass, then you can restore it “normally in iTunes” den you can connect it to your tv, update if nessery, and then you can use season pass again
Well my issue is that when I plug my jb’ed ATV 2 to my computer when prompted by Seas0n Pass nothing happens! I can’t get the DFU mode anymore. Even in iTunes the device is not displayed.
That’s strange because as I did the first jailbeak, everything went very smoothly.
