I’m not sure what happened, but I’m pretty sure ATV Flash automatically saves SHSH blobs to the Cydia servers, right?
I also saved them in the Menu manually, now when trying to downgrade via SP I’m getting the “Not Eligible” error.
I can provide additional information if you need it.
Any help would be great.
-Duff
matty
2
Which iOS are you currently running?
It’s currently on the latest update of 5 (or 5.1 however you want to look at it).
It was on 4.4.4 when it was jailbroken.
matty
4
In the backup settings of the Maintenance menu does it show the blobs for 4.4.4?
Sorry, it is not currently jailbroken.
It’s on the latest update.
The blobs were saved previously.
run latest seasonpass if blobs were saved via menu on atv or tinyumbr,
read tutorial if blobs were saved in ifaith http://firecore.com/comment/reply/7279
