4.4.3 JB Untethered :)
http://www.cultofmac.com/135301/untethered-jailbreak-for-ios-5-0-1-is-finished/
Pad 1 5.0.1 untethered code is done, testing tomorrow with a friend’s device. Just to let you know my progress in real time. iPhone 3GS 5.0.1 untethered code is done. Testing tomorrow also! iPod 4G 5.0.1 untethered too ! :o ). Apple TV 2 4.43 untethered done also. Will be able to test in some days.
Not available yet, but it’s done by the looks of it. Bravo to those people.
Hope they rush a Seas0nPass update now :smiley:
I have mine on a tethered. Given it never. EVER crashes or is turned off, it’s not been a problem. But yeah - untethered would be preferable.
That said,  having airplay mirroring (and iPlayer etc on the iPad) makes even a tethered JB pay off.
Oddly enough I am running 4.3 on my Apple TV and my jailbroken iPad 1 running iOS 5.0 and I can use Air Play without a problem. Only thing I need to do is disable the Auto Lock feature to prevent the stream from stopping while in the middle of playing. But, in Canada, we have a Global TV app and it natively supports Air Play and it works flawlessly.
Still needs a bit of testing, which should start within the next day or two.
http://fireco.re/Cb8z
James: LOVELY :slight_smile:
Glad to see that progress is being made.  I knew it’d only be a matter of time before an untethered exploit was discovered.  Let’s just hope we’re not living on borrowed time and 4.4.4 comes out a day later.
Damn it, I should’ve kept my mouth shut.  Apple TV 2 4.4.4 is out now.
If one is wanting to use the untethered 4.4.x when released, should s/he stick with 4.4.3 or is it anticipated that it will also work with 4.4.4?
Since SeasonPass now supports 4.4.4 in tethered mode, when the untethered JB becomes available I would be very surprised if it did not also support 4.4.4.
hi,
when relesead ? (pod2g  untethered Apple tv2  4.4)
any process?
