4.1.0: AppleTV2,1_4.1_8M89_Restore.ipsw
I find myself with An Apple TV2 on stock firmware 4.0 iOS 4.1.1
I want to jailbreak it UNTETHERED
None of the versions of Seas0npass that I can find go back further than :
4.2.1: AppleTV2,1_4.2.1_8C154_Restore.ipsw
Does any older version of Seas0npass go back any further?
In hindsight I did think it was very cheap.
Cheers
i used snowbreeze to jailbreak mine.  I just can’t get atv flash black to work.  I had to use putty to install xbmc.
Check out this site: http://www.downloadios.net/
Good luck
@ jamesleber - if you use Sn0wbreeze to jailbreak the ATV it adds NitoTV and you use that to install XBMC.
@ Carpenter940 : Thanks but perhaps I didn’t explain myself.  I have found the IPSW for the version I need but I cannot get Sn0wbreeze to make the patched IPSW (it stalls at patching root FS) and Seas0npass does not offer to download IPSW as old as I need … Ergo, I need a really old version of Seas0npass.
Hi
I have JB a couple of the old iOS and was successful with green poisi0n.  some links on the following page.  Install xbmc through NITO
OK, thanks, I’ll take a look at those.
this is another link for downloading more IOS than the one mentioned earlier and it does even has the latest 5.3, don’t instal the 5.3 though!
http://www.icj.me/ios/
Nice one, thanks.
So what happen did u jAilbrok it. And what snowbreez version is working for this iOS ?thx
