I tried to do an upgrade to 3.4.5 and have tried several times using the same flashdrive I’ve been using for the previous versions. I’ve even re-formatted it again and tried but each time I ran it on the AppleTV, it gets stuck at the message STARTING LINUX…
Anyone experiencing this problem and any ideas why this is happening?
My installation got stuck too (maybe at a different point), I guess my flash drive was not compatible because it worked when I tried a different one.
Ryan is right, I’ve seen it where flash drives work with older versions but will not work with the current one. I have been using an iPod Shuffle 512MB original white one and now it does not work. Now I use a HP 2GB USB Drive.
