3.4.1 with 2.2
This may be a silly question, but can you upgrade to aTV 3.4.1 without upgrading the appleTV to 2.3. ??
Thanks,
Bill
I would say you can use 3.4.1 with 2.2, but there might be some of the third party plugins that may not work 100%. It just depends if Apple changed something in 2.3 which the developers had to also change in their plugin for 2.3 compatibility.
