2tb drive and time capsule
Anybdoy tried hooking their large drives to their time capsules and then mounting on atv? I am having trouble getting the time capsule to recognize the drive even though atv sees it when plugged into the atv. I want to do this so the large drive is available to both my 1st gen atvs… It is formatted as Mac os extended journaled… It is an iomega ego powered drive. Thanks.
This is definitely doable. You will want to setup a share point through the nitoTV > Network menu and specify the external drive's name as the 'Volume Path'.
More details on setting up share points can be found here.
