It is possible or planned that Infuse could in the future « interpolate » or « resample » in real time any 24.000Hz framerate to 23.976 Hz for the ATV to avoid this limitation ?
Any thechnical limitation (power) or is it avoided by Apple ?
For your bluray archives, you could always remux the files with the FPS flags set to 23.976. That should fix it on that end, though proper 24hz refresh rate from the APTV would be preferable.
Just make sure to run the audio through EAC3TO or somesuch first to avoid audio sync issues.
From avsforums:
„I meant to add above but I’ll add here as I see the conversation has moved on; there is one possibility that a media player such as Infuse could implement which would “fix” the issue; if it dynamically sample rate converted the audio to match the 23.976p video clock then the video could be player at 23.976p with the audio staying in sync and no dropped frames. On the PC a DirectShow filter called ReClock allows you to do exactly that. It would be quite processor intensive though to do to a high quality. Having said that, I see Infuse appears to implement all kinds of audio processing so it is possible they have this capability (I’m not very familiar with it).”
It’s less about infuse supporting it and more about Apples hardware not supporting it. This is a problem that exists on other AppleTV video apps including Netflix.
