21:9 subtitle position for soft subtitles
Just bought Infuse 5 Pro and like it a lot but I have 1 suggestions about subtitles. The original subtitle postion is to low for a 21:9 screen if you have a soft subtitle. You can get it in right postion if you move it about 3 clicks up. But if you then start a movie with PGS with correct 21:9 subtilets the subtitle will be to high in postion. Maybee is possible to have idependet settings for soft and image based subtitles?
I want use Infuse 5 pro in my home theatre,but my screen is 2.35:1, the subtitles is out of screen when play film. So please add subtitles position adjust function. like oppo blueray player.
