2 Metadata issues in v7
  1. When a movie has a common name, it is unlikely to be found by auto-match or “Edit”, for example file name:
Wish.2020.mkv
(Wish (2020) — The Movie Database (TMDb))
It returns some results but none of them is correct.
How to specify search conditions in “Edit”?
  1. TV Show season cover.
I used to put season cover as folder.jpg in each season’s folder, it worked fine before but not in v7 for some TV shows. I noticed that it didn’t use folder.jpg if season folder name is like “Tom and Jerry Season 1940” (Tom and Jerry - TheTVDB.com, it is called Season 1940/1950/1960 instead of Season 1/2/3…), I changed folder name from “Tom and Jerry Season 1940” to “Season 1940” or “Season 1” and it picked up folder.jpg.
5 posts were merged into an existing topic: Improve Accuracy really important!
