I have successfully jb atv2 with ios5 and install xbmc. I have 1 question. Is it normal to access xbmc with 2 clicks. 1 click via the main screen and it goes to another screen with just a xbmc button. I need to click that before I can access the xbmc home screen. Is this normal?
Thanks.
Same thing happens for me as well, so I’m assuming its normal. Although, it is annoying. Just clicking the main screen app sould be sufficient enough. Unless they plan on putting some type of settings there. Maybe settings to put it in the top row? That would be cool.
Glad I’m not the only one.
