Hi Guys!
I have a 1080p mkv video file. What is the best way to play it with atv flash jbed atv2 with file on a synology DS110j NAs?
Could i change the file format simple to avi or mpeg?
Hi Guys!
It depends on the audio/video codecs inside the mkv.
mkv, avi, mp4, etc. is all just a container for different video, audio, subtitle streams. Chances are you’ll be able to play that video file on the ATV2 just fine with ATV Flash. Don’t change it into .avi… .mkv is a more capable container. But if you’re finding it unplayable, the fact that it is an mkv isn’t the issue. The problem will most likely be that you’re trying to play an incompatible codec.
