10 Sec Forward not working
I tested on both v4.0.1 and v4.0.2 (beta), only the 10 sec rewind works, the 10 sec forward doesn’t when I tapped on the edge of the touch pad.
Anybody having the same problem as me or is it just me. Thanks!
You should not tap. Tapping only displays the playback bar, then you PRESS the sides it moves 10 seconds. (I don’t use this, because the loading indicator also takes 6 seconds to start playing again, so for me it is not useable yet.
You should not tap. Tapping only displays the playback bar, then you PRESS the sides it moves 10 seconds. (I don’t use this, because the loading indicator also takes 6 seconds to start playing again, so for me it is not useable yet.[/quote]
Sorry I used the wrong word “tapped” :slight_smile: It should be “pressed”.
Yes, I did PRESSED the edge but the video did not forward 10 secs. I tried many times and it still didn’t work. The 10 secs rewind did work though.
Anybody encountering sure issue? Thanks!
You probably have Chapters set to ON in Settings. Check it to off and it will work.
