when swiping down watching a film… I have trouble getting subtitles from Opensubtitles.org. any other that have the same prob…
Message says: could not download sub… please control your network connection and try again…
Do you happen to be located in Norway or Denmark? If so, it appears OpenSubtitles recently became blocked in these countries.
One user found a workaround which may help.
James: Yes I am located in Norway
Thanks James: Problem fixed, just changed DNS on Atv to google 008.008.008.008 and voilaaa
How? How to manually update DNS settings on your Apple TV | iMore
Is there a solution for a wired setup? I’m pretty sure last I tried I couldn’t do it while using ethernet.
It’s possible to change the DNS on Ethernet on ATV4+4K
Settings > Network > Ethernet > Configure DNS
