Library View & Use Local Metadata, does it only work with SMB shares ?
If so maybe you need to update the blog to mention it.
“Mark folders to use embedded metadata only”, could we have a not use any metadata too please.
Correct, Library View does not currently work with UPnP/DLNA devices as their links are dynamic and can/do change often.
We’re currently working on a list view option for the upcoming 4.3 version, but we’ll still be showing some amount of metadata. In list view this would likely be limited to a thumbnail and the title (or filename if you have the option enabled).
