How to get Pro
Infuse Pro is available as a subscription (Monthly or Yearly) or as a one-time purchase (Lifetime). All future updates (even major releases like v8, v9, v42, etc…) are included with all in-app purchase options.
Download Infuse 7 (free app w/ optional in-app purchase)
Family Sharing
Family Sharing is supported for both in-app purchases and subscriptions. Learn more about Family Sharing
Tips for Family Sharing (iOS 14.2 and later)
- Family member(s) have been added to Family Sharing with Purchase Sharing enabled (Note: Both the account sharing the purchase and the account using the purchase need to activate Purchase Sharing)
- For monthly/yearly subscriptions, ensure sharing has been enabled in the Infuse subscription page (App Store > Subscriptions > Infuse)
- Tap the Restore button on the purchase prompt (if it appears)
Note: In some cases it may be necessary to delete and re-download the app from the main family member’s list of Purchased apps in the App Store.
Alternative option for Family Sharing via Trakt (can be used between App Store regions)
- Log into Trakt on the purchaser’s device in Infuse’s Settings menu (Note: On iOS/macOS, look for the orange Trakt icon in the upper right corner of the Settings menu).
- Log into the same Trakt account on other devices
Upgrading to Infuse 7
Those upgrading from older standalone versions (Infuse Pro 4, Infuse Pro 5, Infuse Pro 6) can get a free year of Infuse Pro!
To take advantage of this follow these steps.
- Install your latest paid version of Infuse (v4, v5, or v6) and ensure your Pro features are active (look for the Infuse Pro text/logo in the Settings menu)
A. Paid app or In-App Purchase are both fine
B. If needed, you can re-download Infuse through the Purchases section of the App Store as described here). - Download Infuse 7 and tap the Upgrade to Pro option in Settings
- Choosing the Yearly subscription option will provide you with a free year of Infuse Pro (Note: ensure the 1 Year Trial text appears below the price…please contact us if you don’t see this)
- After upgrading in v7 the old app can be removed
Thanks for using Infuse!
